question about thermostat
Old Sep 22, 2002 | 02:57 PM
ROB'S SS's Avatar
Default question about thermostat
has anyone ever taken apart the thermostat and just used a plate with a hole in it like the old days? then just use the fans to keep the engine at a certain temp? ive been thinking about doing it lately.
Old Sep 22, 2002 | 05:23 PM
jimmyblue's Avatar
Moderator
Default Re: question about thermostat
A restrictor gives you flow and heat flux
that's proportional to RPM only. This might
be OK for steady-state RPM and load, but
it won't track temperature like a thermostat
will. It's better to have a thermostat that
maintains temperature and flows like (or
better than) the restrictor, and have fans
that keep radiator temp below the thermostat
crack-open point.
Old Sep 22, 2002 | 07:47 PM
NC Guy's Avatar
Amen,
More LS1 owners need to understand that they should run a T-Stat either on street or strip. A restrictor will work for race tracks only.
Enjoy your cars
