Dipstick in way of headers
Old Sep 28, 2002 | 11:35 AM
sited12's Avatar
Default Dipstick in way of headers
How do you get the exhaust manifold off with the dipstick there and how do you get the header on with it. I have hooker headers if that helps any.
Old Sep 28, 2002 | 11:43 AM
Jason99T/A's Avatar
I can shift faster than you.
Default Re: Dipstick in way of headers
Take the dipstick out. It's just a 15mm bolt on the cylinder head.
Crazyquik's Avatar
When doing my MACs I had to remove the dipstick, put the header in place, then replace it, then tighten down both.
J.
Old Sep 28, 2002 | 11:46 AM
sited12's Avatar
i removed the 15 mm bolt. Does it just pull up then. I looked at the bottom and it went into the block but couldnt pull it out. I guess i will keep pulling.
Old Sep 28, 2002 | 03:22 PM
John B's Avatar
Moderator
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif"> i removed the 15 mm bolt. Does it just pull up then </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yes, you may have to twist it back and forth slightly due to the o-ring that seals this to the block to prevent leakage but it'll come right out, nothing ther to break so don't worry.
Old Sep 28, 2002 | 09:53 PM
GeorgeC's Avatar
I don't recall an o-ring on the dipstick tube. <img border="0" title="" alt="[Embarrassed]" src="gr_emb.gif" /> Or am I being the "dipstick" here?
Once you get the 15mm bolt out, it should just pull straight out.
Old Sep 28, 2002 | 09:59 PM
GeorgeC's Avatar
I just verified that there is indeed an o-ring... Looks like I am the dipstick here. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Anyway, it just pulls straight out...
Old Sep 28, 2002 | 10:42 PM
sited12's Avatar
Just wanted to tell you guys are awesome. Both questions i had about this install were answered within less than 30 mins. Headers are loud as hell. Now i need some mufflers. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
 Michael S. Palmer
