Which size injectors are you running in your 408-436ci NA setup??
LS1Tech Co-Founder
I am running Bosch whitetop OEM style injectors (from a GTP), and I get some surging at idle which makes me think the car is loading up in spite of the tuning we have done.
Please list your injectors.
<small>[ October 02, 2002, 11:46 AM: Message edited by: Pro Stock John ]</small>
I have the same as you. They are all white GM injectors for 3800 SC'd Monte Carlo part # 24508208 for my 427 C5R street machine. Also got a 340 Walbro intank. A/F ratio was 12.5 straight across the dyno to 6800 rpm.
Leo
Leo
PSJ: Are the offset values for the GTP injectors the same as the LS1 injectors? You may be scaled right, but not correcting the offset can leave you skewed at one end of the scale. I know the 30lb SVOs tend to cause the light throttle and idle to run rich if the offset is not corrected.
LS1Tech Co-Founder
Joel I do not know but I'll ask Intmd8.
Apparently MTI uses 30lb svo's for all their big NA setups. Any MTI folks looked at duty cycle or pulsewidth during track runs?
Am I barking up the wrong tree here, I do notice if I get off the gas real fast sometimes it backfires or loads up. Car does surge at idle.
I can shift faster than you.
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Pro Stock John:
<strong>Apparently MTI uses 30lb svo's for all their big NA setups.
</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">This is all we use as well. They are good for well over 550rwhp.
</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">This is all we use as well. They are good for at least 550rwhp.
Delphi 37lb worked great on the old setup and they should be fine on the new one.
Dave
S.A.M. 436
www.thebeasst.com
<small>[ October 09, 2002, 07:50 AM: Message edited by: The BeaSSt ]</small>
Dave
S.A.M. 436
www.thebeasst.com
