MagnaFlow Ultra High Flow and Compact Metallic-Cat Product line
Originally Posted by joecar
oxidizr, good info, thanks. ![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
Originally Posted by 02RedHawk
Excellent! Hope to run a pair of these on my Trailblazer-SS headers!
Question though, why not make these have an inlet-ID and an outlet-OD for proper exhaust slip-fit attachments???? (that is, for example a 2.5" ID on one side, and a 2.5" OD on the other side....)
I don't understand why this wouldn't be standard practice.![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Originally Posted by oxidizr
ID / OD means you have some means of expanding pipe. Most hoem users do not. We use ID/ID so all you have to do is cut your 2.5" OD pipe and slide it in both sides.if you have the capability to bump tubing you can bump the tube over the 2.5 ID nipple anywayso it shoudl not be a problem.
AutoZone has various size exhaust pipe expanders available as loaner tools, very simple to use;
using this you can expand the downstream pipe to fit over the upstream pipe.
I'm thinking ahead when the cats "wear" out and need replacement, but they would have to have the 4 bolt flange so they would bolt right up to the collector ring.
(...and also, being in Cal. it may be wise to be able to show an EO # for the cats if not for the headers).
#32
Joe Car:
No cat would be CARB legal on LT headers ... unfortunately relocation of the cat makes for automatic failure. Our currrent OBDII CARB cats will pass the sniffer but again do to the relocation they would NOT be considered legal.
RrCoX22:
I wil have to check with sales as these numbers have been released.
Sean's SS:
One reason would be additional flow. If the cats are ceramic 400 cell cats the MagnaFlow Ultra-Flows are goign to make for a substantial increase.
RevGTO:
I'm looking for info from sales on availibility of pricing.
JL - WS6:
Indeed ... stainless core and shell.
RrCoX22:
Sean's SS:
RevGTO:
JL - WS6:
#35
Originally Posted by RrCoX22
oxidizr - dammit, hurry up man! ...j/k but you have a few people waiting for these prices
(and yes these are some beautiful looking cats)
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
#38
Joe Car:
I understand that relocating the cat fails the visual, that's my responsibility.
