Raptor shift light not working :(
Old Apr 19, 2006 | 04:33 PM
davered00ss's Avatar
Moderator
Default Raptor shift light not working :(
Any Idea what to check. It worked last summer. First time I took the car to 6K this year, no light. Set the light to 5K, still no light up to 6K. Do they have a fuse in them, or chould I just check all the connections?
Old Apr 19, 2006 | 05:25 PM
LoWeLL216's Avatar
There's no internal fuse in it. You could check the fuse of whatever you tapped for power, but I doubt that's it. More likely a connection.
Old Apr 19, 2006 | 05:33 PM
crazy3rdgen's Avatar
could you hook one of these up with no drilling? I always wondered if I could get like a suction thing you use on windows, somehow hook it up to the light and then to the far left of the window stick it to.
Old Apr 19, 2006 | 05:35 PM
RyRy's Avatar
you could probably do that. I did what a lot of other people did and mounted it in the air vent above the stereo. No one ever notices it until I point it out...
As far as the shift light not working, Id check the connections like Lowell said...
Old Apr 19, 2006 | 05:40 PM
mellowyellow's Avatar
Does it lite up when you turn the key to the run position ?
Old Apr 19, 2006 | 06:10 PM
LoWeLL216's Avatar
I also put mine in the vent on the pillar. Just pull the little plastic vent out and replace it with a rubber grommet. The raptor light fits in it perfectly and doesn't move. Looks really clean.
Old Apr 19, 2006 | 06:51 PM
Moderator
No, but it never did.
Old Apr 19, 2006 | 07:05 PM
Moderator
I placed mine in the fog light switch.\
Old Apr 19, 2006 | 07:52 PM
Johnny5's Avatar
They are supposed to light up and go through a sequence when you turn the car on. If it isn't doing that you may have the dip-switches set incorrectly, a bad ground, or your connection to the tach wire might be loose.
Old Apr 19, 2006 | 08:15 PM
Moderator
I think it was not going through the start up is because of where I ran the power from. It did always work when I reached the RPM's. Now does not work at all. I'll check the wiring tomorrow.
Old Apr 19, 2006 | 08:41 PM
badpewter-z's Avatar
LS1TECH Sponsor
sounds like it lost its power dave. make sure the connection at the pcm is still good and connect the power to a ign switched 12v source. it has to do the slef check espically if you change it so you can confirm where its set. make sure the ground is still connected too. did you even do any interior stuff this winter?
Old Apr 19, 2006 | 09:01 PM
bastien's Avatar
check the connections. start over if you have too
Old Apr 20, 2006 | 03:31 PM
Moderator
Keith, I checked the Pink line I drew power from and there is no power there. I did not use the #19 pin like I should have. I will just cut the power line and tap off the one I should have the first time.
Dave
Old Apr 20, 2006 | 03:47 PM
LS1TECH Sponsor
Dave
Old Apr 20, 2006 | 04:31 PM
dnm12's Avatar
yep its got to be the wiring
Old Apr 21, 2006 | 07:41 AM
Moderator
You know how I work unsupervised.
Old Apr 21, 2006 | 10:48 AM
Moderator
I tapped into the pin #4 when I initially did the install. The wire is pink. The raptor performance web site says #4 is Air Silinoid Relay Control, but says the wire is PPL. This would make sence as to why it does not work, because I deleted the Air system.
I'm thinking I should check for a fuse just in case.
Old Apr 22, 2006 | 01:38 PM
Moderator
Tapped the #19 pink wire. works perfect now. I disabled it when I disabled the Air system.
