little help?
Old Apr 19, 2006 | 05:34 PM
Syxx613's Avatar
Default little help?
hey guys. ive never had an engine apart before and i need to get the harmonic balancer off. do i need a pulley puller for it? and can i get the bolt off without using an impact? ive got a socket that will fit but its a hard mother effer to break loose. any and all help is always appreciated. thanks guys!
Old Apr 19, 2006 | 06:50 PM
WhiteRhino's Avatar
You can use a 3 jaw puller. You can get the bolt loose by hand, but you need a long bar for leverage. You need to lock the flywheel as well.
Old Apr 21, 2006 | 05:32 PM
Syxx613's Avatar
ive got the engine on a stand and the balancer is locked.however i cant seem to break this ****** loose. is it reverse threaded? do i just need a long *** breaker bar? thanks
Old Apr 21, 2006 | 05:42 PM
conan's Avatar
I use a 18" braker bar with a 2' jack handle on it. No it's not reverse thread. If you have a buddy have him hold the socket to the bolt to prevent stripping.
