fuel rail/injector re-install help needed
Old Oct 6, 2002 | 07:33 PM
jeromio's Avatar
Default fuel rail/injector re-install help needed
Alright, I did a search on this, I must be a total dumbass. I am having trouble re-installing the fuel rail. I have all the injectors in place with their O rings. I managed to get the rail to seat on the passenger side injectors, but the driver's side is giving me trouble. The 2 injectors near the firewall seem to be seated in the rail, but not in the manifold. The front 2 are the opposite. I have the clips installed on those back 2, but the front - no way. They're sunk deep into the manifold but are pretty far from each bung. (also, I seem to have lost one clip <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" /> ). And one of those passenger side injectors is not quite seated all the way into the rail since the clip doesn't completely snap on all the way to the lip of the rail bung.
So, what's the trick?
I'd really appreciate any insight into this chore.
Thanks
<small>[ October 06, 2002, 07:36 PM: Message edited by: jeromio ]</small>
Old Oct 8, 2002 | 02:58 PM
jeromio's Avatar
Default Re: fuel rail/injector re-install help needed
Anyone? Too stupid a question?
I'm stuck, literally. I don't want to turn on the fuel pump and have 50PSI fuel spraying all over the place....
Old Oct 8, 2002 | 03:19 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Be gentle little one otherwise you will split the o-rings.
I have taken the injectors out and left them in the rail.
Old Oct 8, 2002 | 07:47 PM
Tin Indian's Avatar
PSJ is right about leaving them in the rail.
I would take it apart, then install all the injectors in the rail.
Next, put some vasaline on the injector O rings that go into the manifold, and then push it all down as a total assembly.
Old Oct 8, 2002 | 10:30 PM
jeromio's Avatar
Aha! Now we're getting somewhere. I had not considered assembling injectors/fuel rail first.
Thanks.
Old Oct 10, 2002 | 08:30 PM
MIGHTYMOUSE's Avatar
i just use some oil (open oil cap, rub finger in oil cap, rub oiled finger on o rings) and put them in t rail first.. those clips are not necessary.
