Okay to pull AIR pump fuses after I remove the pump?
Old Oct 8, 2002 | 01:13 PM
quickWS6's Avatar
Default Okay to pull AIR pump fuses after I remove the pump?
I have removed my AIR pump. Is it okay to pull the two fuses for the AIR pump? How will this affect SES codes? Thanks for any help.
Old Oct 8, 2002 | 07:08 PM
02 Silver Z's Avatar
Default Re: Okay to pull AIR pump fuses after I remove the pump?
ttt
Old Oct 8, 2002 | 07:12 PM
99taws6's Avatar
It will effect the codes.... You will need to program them out with LS1Edit or something similar
Old Oct 8, 2002 | 07:17 PM
Benjamin Russick's Avatar
I took the fuses out, but I already had a prior code.
