WTF is this Banging?
Old Oct 8, 2002 | 09:03 PM
01Z0H6's Avatar
Default WTF is this Banging?
Put on my LGM Y pipe today & it feels like my Trns mount is busted! But i know it is not!
Talked to Rick @ LG & he said i had to get a hammer & 2/4 & knock up this portion of my undercarriage!! WTF!! Help!
Matt
BTW car runs Great!
Sounds Awsome with the Borla! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Oct 8, 2002 | 11:18 PM
felton316's Avatar
Default Re: WTF is this Banging?
More than likely the y-pipe is banging the floor board. Look under the car for 'rub' marks and thats where you need to do a little modification with the hammer. You could also try pulling the y-pipe down so it will hang lower and not hit the car.
Old Oct 9, 2002 | 01:41 AM
DARK AGE 53's Avatar
Take hammer to the undercarriage, I don't think so ( not if it were my car ). Two things I would try, first check to see if it's a clamp hitting the floorboard, second, loosen the clamps up and try repostioning the y-pipe. If it still bangs I'd send it back for a refund. We've installed SLP's y-pipes on two different cars and have had zero banging, good luck.
Al
Old Oct 9, 2002 | 02:32 AM
Tin Indian's Avatar
You may see a crossbrace just about where the y-pipe and the intermediate pipe join. If this brace is still installed in your car, the pipe may be hitting it. If so, just remove the brace. You don't need it.
Mine has been removed since 99. No problems.
Ron,
Old Oct 9, 2002 | 09:29 AM
sweetTA's Avatar
My $3 Banging ORY fix:
Materials Needed:
(1) 3" Band Clamp
(1) 1/2 or 3/4 Piece of heater hose ~2" long
(1) Flathead Screwdriver
Take the band clamp, open it all the way up, and run it through the heater hose. Wrap it around the Y-pipe wherever its hitting the floor pan. You may or may not have to pry the Y pipe down a little bit. Close it and tighten, and you're done
5,000 miles, no melting, looks just like the day I put it on there, and the bang's gone <img border="0" alt="[pimp]" title="" src="graemlins/gr_pimp.gif" />
Old Oct 9, 2002 | 10:39 AM
01Z0H6's Avatar
Hey men, those are ALL Awsome ideas!
I will crawl under there this weekend & ponder which one to utilize!
Thanks so much for your input!
Matt. <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
Old Oct 9, 2002 | 10:51 AM
98TAauto's Avatar
my SLP offroasd pipe banged in 2 places. Right under the drivers side seat and where the cross brace was. Take the cross brace off. I run the SLP drive shaft loop cross brace minus the loop cause the loop wont fit my car. Its the brace with the 2 inch dip in it.
where it banged under the drivers side i just flattened the pipe a little bit
Old Oct 10, 2002 | 12:19 AM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Kimchee and Rice:
<strong>You may see a crossbrace.... If this brace is still installed in your car, the pipe may be hitting it. If so, just remove the brace. You don't need it.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Forgot all about that brace Ron, good point about it hitting the brace. I'd have to disagree with you about removing it though, the best thing would be to get for longer bolts and put about 3/4" of flat washers at each bolt hole. That would lower the brace enough so it won't hit, here's something to think about, do you think GM would have put that brace on just for the hell of it. I've said this before, if GM could eliminate one washer on a car they would... that brace is a lot of washers. JMO
Al
 Michael S. Palmer
