MAF Sensor direction!!!
Old Oct 9, 2002 | 03:58 PM
Red Hot 2000 SS's Avatar
Default MAF Sensor direction!!!
I just installed a SLP MAF sensor, smooth bellows, and airbox lid. Does it matter which way I put the MAF sensor. I didn't realize until I was done that the part that say's SLP is at the top and not on the side. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Oct 9, 2002 | 10:45 PM
MIGHTYMOUSE's Avatar
Default Re: MAF Sensor direction!!!
put it so the arrow points toward the intake and not the lid.
Old Oct 10, 2002 | 12:27 AM
SS-35th's Avatar
Don't feel bad man I did the same thing. The part that says SLP should be on your right the same way the stock MAF unit is.
Old Oct 10, 2002 | 12:29 AM
SS-35th's Avatar
You also want to make sure that the notch on the MAF and the notch on the bellows and hose clamp are lined up.
Old Oct 10, 2002 | 05:27 PM
Does it really matter, should i try and put it so it sits on the right side(drivers side)? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Oct 10, 2002 | 05:34 PM
Old Oct 10, 2002 | 05:45 PM
SS-35th's Avatar
I did with mine it seems to make the car idle smoother + when everything is installed properly it seems to fit much better
Old Oct 10, 2002 | 06:53 PM
1CAMWNDR's Avatar
Arrow pointing toward the intake manifold.
Old Oct 11, 2002 | 06:02 PM
turbohawk's Avatar
Putting the MAF backwards makes it run richer.Maybe some cars like it especially if MAF mod went wrong!
