Port and polishing TB..
Old Oct 9, 2002 | 07:10 AM
MrWS6's Avatar
Default Port and polishing TB..
I already have a ports Throttle body on my 422 but a friend wants to get his ported. Can someone give me the details if its possible to do it himself?
Old Oct 9, 2002 | 09:00 AM
Superman's Avatar
Default Re: Port and polishing TB..
I did mine myself... used a dremel.. came out nice.
I did notice a 'slower back to idle' reaction after ..
Old Oct 9, 2002 | 01:35 PM
MrWS6's Avatar
wow man great info and the pics were prefect thanks!
Old Oct 9, 2002 | 02:48 PM
Jasc's Avatar
Nice pics jmX
Steve
Old Oct 9, 2002 | 06:17 PM
Raughammer's Avatar
D(irecto)r Pepper
Moved to the external section.
Good luck with your TB.
John
Old Oct 9, 2002 | 06:22 PM
FstBlkz28's Avatar
jmX, what kinda epoxy did you use? How big did you make the hole in the epoxy?
Good job, looks great.
Old Oct 9, 2002 | 06:30 PM
LS1derfull's Avatar
Remember you need two holes in late model LS1 T.B. one for pcv system vent and other for I.A.C. i make mine around 5/16" each. Also dont forget trimming blade screws and thinning shaft, also full throttle mod is worth something also.Last but not least put idle screw in from top so you can adjust with out removing T.B. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Oct 9, 2002 | 06:48 PM
jmX's Avatar
jmX
Thanks for the comments.
I used JB Weld and made sure I got the stuff WAY down into the hole, filled it in inside there too so that there was no way it could become dislodged during engine operation.
And guys, keep in mind the pics are a C5 throttle body. The principal is the same for the Fbody throttle body except you have to put 2 holes instead of one (as stated)...C5's dont have IAC, nor a bumpstop mod, nor an idle set screw. Either way, drill 2 holes instead of one and you are set to go on an fbody.
I think the hole was 1/4" or so. Its just a fresh air vent tube for PCV, nothing that requires any sort of exact sized hole.
Old Oct 9, 2002 | 06:55 PM
BensZ28's Avatar
Def nice job, does anyone know how much hp a come just like this will give you? jmX can you feel a difference? I might have to try that this weekend before I make my last run at the track before it closes for winter <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
Old Oct 10, 2002 | 12:14 AM
jmX's Avatar
jmX
I recently started porting mine (with a dremmel). I still have a lot of work to do, but you can see its not all that hard. Just get a sanding/grinding set of bits from walmart (mine cost me $11.96 I think), sand down the big ridge and make it a smooth transition to the mouth. Grind down the shaft the blade sits on a bit, but DONT change the bore size around the blade or else you'll screw up your idle.
<img src="http://home.austin.rr.com/tyr/c5/tb_port.jpg" alt=" - " />
Old Oct 13, 2002 | 10:03 PM
BensZ28's Avatar
I just did this today, and, what kind of dremel tools did you use!? The sandpaper ones wore out on that metal in like 10 seconds. I ended up using like grinding stone kinds, those worked, but slow and more rough that yours. What did you use? Man I guess this looked easier than it was...oh well at least ill gain SOMETHING...
Old Oct 14, 2002 | 09:47 AM
LS1derfull's Avatar
I port them with carbide burrs,polish with sanding roll cartridges. As for performance difference people state 6 to 10 hp, but i will say this mod smooths out turbulence in intake path and this is something you can feel when driving in all ranges.Your car will growl louder too with wot mod and port polish, all good in my book! <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Oct 14, 2002 | 01:35 PM
slick98ta's Avatar
Hey guys,as far as epoxy goes.Go to Sears hardware in the plumbers section and get some stuff called plumbers epoxy.It comes in a tube,and it like a chemical reation when you work it together like play-doe.Then you can work it with your hands real well.Its hard as a rock withih 5 min so you have to work fast,and bonds to all metals.Even says on the tube automotive use <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> This is the ****!!! and only $6.
Good luck
Mark
BTW: I'll take some pics sometime if you guys want.
Old Oct 14, 2002 | 06:16 PM
gwj's Avatar
gwj
From: Live Oak, FL - in the woods where the creatures lurk.
JMX, good info as usual.
As far as the (2) hole sizes go on the F-Bod TB epoxy fill, the hole into the IAC seems to be more critical to maintain decent idle. I started w/a 1/4" and gradually moved to roughly a 3/8" hole. I'm thinking that that is probably max opening for decent IAC operation. For those having idle problems w/cam, might want to square that away beforehand.
Old Oct 14, 2002 | 08:05 PM
BensZ28's Avatar
Could you take pics slick? Another thing, I dont know about the year of the car with the pics above, but mines a 98 and the area where the holes are for the IAT and something else are MUUUCH bigger than his looked, like double. There are 2 holes, one that goes to a tube to a valve cover the other a little sensor. Anyone have pics of the same thing im talking about? where should i put the hole in this kind?
