Installed my Air/Fuel Guaged HELP!!!
thanks
During WOT, the PCM will ignore the O2 sensors and inject fuel based on a "fuel map" which was programmed into the PCM. During this "open loop" mode, you can use your A/F gauge to determine if your PCM is adding too much or too little fuel and make adjustments to your MAFT to compensate.
