Oxygen sensors
Old Oct 13, 2002 | 04:56 PM
BrianLS1's Avatar
Default Oxygen sensors
I need to order new oxygen sensors(for the front) for my Z28..Where is the best place to get these? dealer? sponsors? how much will these cost? I've been told to stay away from the bosch so what other brands is there or is there just a gm brand? appreciate the help
Old Oct 13, 2002 | 05:11 PM
2000silverbullet's Avatar
Default Re: Oxygen sensors
You can get them from a dealer or from a local patrs store. Theres nothing wrong with bosch.
Old Oct 13, 2002 | 05:23 PM
BrianLS1's Avatar
Thanks for the quick reply..another question is will the drivers side work on the passenger side and so on..reason asking is my passenger side showed up bad and I was wondering if I put the drivers side on that side then see if it would show up as bank 2 sensor 1 again on the ses code that way I will know if its for sure the sensor itself or a wire messed up going to the sensor..the car is running extremely rough so I wanna make sure it's just the sensor and not something leading to it...and I've just put on new msd plug wires and ngks..
Old Oct 13, 2002 | 06:53 PM
BrianLS1's Avatar
top
Old Oct 13, 2002 | 09:29 PM
BrianLS1's Avatar
up
Old Oct 13, 2002 | 09:31 PM
Greg Fell's Avatar
I am getting P0300 (engine misfire detected), P0135 (HO2S Heater Ckt. Bank 1 Sensor 1) and PO155 (HO2S Heater Ckt. Bank 2 Sensor 1).
Could this cause my car to perform badly? What is causing these? It has gotten cold lately, and when I start the car it idles poorly and hunts for idle. After drilling the tb and adjusting the set screw, it idled perfect in warm weather.
Could my 02 sensor's be bad?
Old Oct 13, 2002 | 10:35 PM
BrianLS1's Avatar
Yes, both of them are bad..bank 1 is driver side and bank 2 is passenger side and sensor 1 stands for the sensors before the cats which read the air/fuel and it will cause the car to perform very poorly like mine is right now <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
