I know the 01-2 headers dont have the egr fittings...does that matter? I believe it will throw a SES light...but will the car run ok? Any extra parts i need to get rid of the egr stuff....or is that even possible? any help is appreciated.
yes they'll fit, need to have tuning software to take care of EGR, and block off EGR port on intake manifold if you havent already
i cant tune right away but i can block off egr.....will it hurt the car if i dont tune right away? thanks
I think the orientation of the AIR connections changed between '98 and '01-'02. I don't think they'll be a plug-n-play fit, but will require a little "persuasion" of some sort.
Coy
close
- Join DateJan 2005
- LocationO'Fallon, MO
- iTrader Positive Feedback100
- iTrader Feedback Score(4)
- Liked:12 Times in 10 Posts
Quote:
Nope.Originally Posted by 99gator
i cant tune right away but i can block off egr.....will it hurt the car if i dont tune right away? thanks Quote:
Originally Posted by mbrownin
I think the orientation of the AIR connections changed between '98 and '01-'02. I don't think they'll be a plug-n-play fit, but will require a little "persuasion" of some sort. can anyone else help with this question? What kind of persuasion would it take? thanks.
your air should be fine, i believe....i have a 99 and i bought a set of 01 long tubes...all i had to do was make the egr tube longer, not very hard. i think the air is fine. if not block them off if they are long tubes as you wont be emissions legal anyways. good luck.
Quote:
I dont understand, why make the egr longer? My understanding is there is no EGR on the 01 LTs. I plan on a blockoff plate for my EGR on my intake. What should I do about the o2s? I plan on running a ORY or going true duals.Originally Posted by sandro arellano
