Install Headers?
Old Oct 14, 2002 | 11:24 PM
BlkBrdWS6's Avatar
Default Install Headers?
How hard would it be to install long tube headers on a stock 2001 Trans Am WS6 M6? What is all involved, and what would it cost to have it done?
Thanks a lot!
Old Oct 14, 2002 | 11:51 PM
Sickboy's Avatar
Default Re: Install Headers?
Depends on the brand header. I hear that SLP's are the most difficult. I installed Hooker's last night with a friend and we had the headers bolted up in under 4 hours. That is with no air tools and no lift, just a jack and jack stands. We had to take off the steering knuckle and remove the oil filter, diverter. All of this is simple un-bolt and re-assamble. I was impressed on the ease of it all.
Old Oct 15, 2002 | 02:37 AM
sited12's Avatar
I second that on hookers being easy. But i highly suggest you get a friend to help install no matter what brand you get.
Old Oct 17, 2002 | 04:46 PM
robertbartsch's Avatar
I want to continue to use cats ...what do you do with hookers that are sold without a collector flange?
Old Oct 17, 2002 | 04:48 PM
sited12's Avatar
You will need to get a custom y pipe made with the cats in it. Just find a muffler shop around your house and they should be able to make one for you.
Old Oct 17, 2002 | 11:05 PM
TA_2001's Avatar
I got the SLP kit and it came with everything
I needed..
this is how I did the install.
http://ls1info.com/article.php?sid=149
here is the kit
http://ls1info.com/modules.php?op=mo...ery&file=index
Old Oct 18, 2002 | 02:04 AM
buschman's Avatar
I did FLPs with no prior experience. It took time, but you'll be able to figure it out if you're handy with a wrench. But be sure to get spark plugs and spark plug wires. You'll never get a better oppertunity to swap them than when the headers are out.
Mike
