Larger throttle Body ?
Old Oct 17, 2002 | 02:26 PM
01Z0H6's Avatar
Default Larger throttle Body ?
Would i have to "tune" if i went to a larger diameter Throttle Body?
what gains could i expect?
What are your experiences with this mod?
Thanks in advance!
Matt
Old Oct 17, 2002 | 04:29 PM
robertbartsch's Avatar
Default Re: Larger throttle Body ?
pat musi flow bench tested the stock unit and says it flows over 850 , therefore, it will support HP to >600....
...so don;t waste your money
Old Oct 17, 2002 | 05:12 PM
Fenris Ulf's Avatar
The restriction is at the mouth of the composite intake, so a larger TB won't do jack.
Old Oct 17, 2002 | 06:05 PM
BensZ28's Avatar
There are some ruff spots on the stock one, I just got done port/polish/epoxy mine, not much larger but it really smoothes it out and makes for less drag and turbulence.
Old Oct 17, 2002 | 07:31 PM
01Z0H6's Avatar
Thanks men! Guess i won't do that!
Old Oct 17, 2002 | 07:52 PM
SStrokerAce's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by robertbartsch:
<strong>pat musi flow bench tested the stock unit and says it flows over 850 , therefore, it will support HP to >600....
...so don;t waste your money</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">It doesn't flow over 850cfm in stock form and rated at the same spec " of Hg (20.3) that carbs are normally checked at.
A well ported stock unit will flow 825 to 850cfm. Belive me I do it all the time on the flow bench.
For 600hp, I would rather have 1000cfm, the 850 is good for around 550 or so. (basically as much as most heads/cam cars do.)
Bret
