ASP PULLEY
Old Oct 19, 2002 | 01:31 PM
fak005's Avatar
Default ASP PULLEY
Team:
I want to find out if I buy the ASP underdrive crank pulley....does it come with the bolt?
If not, where can I get it and how much?
Also, can I use the stock bolt.
Also, which belts should I use and where can I obtain them.
Thanks,
Adnan K
Old Oct 19, 2002 | 01:53 PM
TomQ's Avatar
Default Re: ASP PULLEY
buy your pulley from thunderracing, they give you everything you need.
You can't re-use stock bolt
Old Oct 19, 2002 | 02:58 PM
vhgjk123's Avatar
on the thunderracing website they have th option to buy many different belts. Which ones do we need and do you actually have to buy them seperate or do they come with the crank pulley if you just order that?
Old Oct 19, 2002 | 03:06 PM
PSU 98's Avatar
11-378K4 Belt for AC Pulley
11-760K6 Accessory Belt for ASP Crank Pulley Only
Those are the belts you want. You'll have to order them separately. The pulley from Thunder Racing comes with a new crank bolt. Note that they are backordered though...
Old Oct 19, 2002 | 03:24 PM
02SilverWS6's Avatar
Hey fak005, how did you obtain the ASC build #? I've sent an e-mail to customer service a couple days ago and nothing yet!! What can I do?
Thanks!
Old Oct 19, 2002 | 05:28 PM
Dane 98 Bird's Avatar
I just replaced my pulley and I had to buy the bolt from the local dealership. I asked for the harmonic balancer bolt for the LS1, and it cost 8 bucks.
Dane
Old Oct 19, 2002 | 06:55 PM
fak005's Avatar
02SilverWS6,
i emailed this person andrea.harewood@ascglobal.com with my vin # and info and it took him weeks to reply back as he/she is swamped with mails. It takes a long time though so have patience
btw, i have silver 02 WS6 also.
Adnan K
