Value of "H" exhaust cross-over?
Old Oct 20, 2002 | 11:37 AM
GMW's Avatar
GMW
Default Value of "H" exhaust cross-over?
How much value in performance and noise reduction is there in installing an "H" pipe or cross-over pipe between dual exhaust pipes? I have 2.5" dual tubing going back to an Edelbrock 5512 (2 X 2.5" in, 2 X 2.5" out) muffler. I'm not running cats. I'm thinking of installing an "H" pipe or cross-over between the duals close to the engine but past the O2 sensors. Is there any significant value in doing this? Thanks in advance for your help!
Old Oct 20, 2002 | 11:49 AM
NOBR8KSS's Avatar
Default Re: Value of "H" exhaust cross-over?
EVERY dual exhaust setup should have some kind of balance pipe, whether it is an H or an X. You may not make more peak hp, bu the area under the curve will be greater. I have seen a gain of as much as 25 rwhp at 5000 rpms (on an LS1) from an X-pipe.
Old Oct 20, 2002 | 06:58 PM
jimmyblue's Avatar
Moderator
Look at it like this... on a pulse by pulse basis,
with an ideal balance tube each exhaust pulse gets
twice the cross-sectional area to escape. That
leaves aside the issues of resonant scavenging
in engines with uneven intra-bank firing order,
which the balance tube also really helps with.
The X-pipe is a more flow-friendly update of
the venerable H-pipe, it imposes no right-
angle turns when properly constructed.
