Do pullies help more with top end or low end
If you want to split hairs on the subject, it may benefit you slightly more up top because friction and loads on the auxiliaries will be greater at higher RPM.
I picked up 12rwhp and 20 rwtq with mine. These numbers are not exact however, because on my previous dyno before the pulley, I had my tires at 25psi, this run they were at 40psi, so my gains from the pulley are most likely lower than 12/20.
<strong>It should help all-around.
If you want to split hairs on the subject, it may benefit you slightly more up top because friction and loads on the auxiliaries will be greater at higher RPM.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I agree, they help everywhere but more the higher rpm you are turning. It's not only the laws of friction but the laws of inertia that make this so. Also, pulleys will help you more the higher numerical ratio rearend you're running. Why? Because you are trying to accelerate the accessories faster with 4.10s than with 3.23s plus you're turning them more times over the course of the 1/4. You stand more to gain from slowing them down. Again, friction and inertia.
