Throttle Cable issues
Old Apr 24, 2006 | 11:18 PM
Haans249's Avatar
Default Throttle Cable issues
Hello Everyone,
I did a little maintence on my engine today, which involved disconnecting my throttle cable line from the throttlebody. Well, before all this work, my throttle cable system worked fine. Now, the blade won't close all the way, and I have to manually force the blade closed, and sometimes it won't stay closed. Then, I hit the gas while sitting at idle, and the throttle plate stuck open, so I shut'er down, and my cruisecontrol motor was clicking weird and I had to manually pull on it to get it to stop even after the engine was off...This is a 2001 TA wS6.
WTF is up with my throttle cable system, anyone have any suggestions? It's not driveable the way it is currently.
Best Regards,
Adrian
Old Apr 25, 2006 | 12:28 AM
Shallow Bay's Avatar
Are you sure you put the throttle cable back on the throttle body right?
Old Apr 25, 2006 | 12:35 AM
Texas-TA's Avatar
I would just retrace your lines cause there isnt much to mess up there. Let us know bro
Old Apr 25, 2006 | 09:07 AM
thunderstruck's Avatar
is that cable adjuster piece still together? it has came apart on me before
Old Apr 25, 2006 | 09:30 AM
Haans249's Avatar
I'll check all of the above a little more thoroughly, thanks for the suggestions.
Best regards,
Adrian
Old Apr 25, 2006 | 02:40 PM
Any chance you could post up a picture of what it looks like?
Old Apr 25, 2006 | 04:14 PM
Haans249's Avatar
Its the cruise control mechanism. Its directly behind the battery, and you can take that top cover off via some push levers on the sides of it. It just pulls right up. I messed with it some more, and tugged on some lines here and there and it appears to have fixed it....who knows lol...
Best Regards,
Adrian
