Car is trying to die when coming to a stop
The cars mods are:
A4/stock stall
Mac headers/bullet muffler
lid
GMAF
I don't think that any of these mods could be causing it because they have all been on for quite a few months.
PLEASE!!! any help will be greatly appreciated.
Thanks,
Blake
<strong>Sounds like a vacuum leak to me. Check for any sucking noises w/ the hood open.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I agree. It does sound like a vaccuum leak. Have you recently messed with the egr or AIR system? If not properly sealed, you'll get a leak and you'll hear a sucking/hissing noise. This happened to me when I removed the egr from the intake manifold. I bent the tube and it didn't seal properly. It would barely idle and it almost died a few times.
It will drop to 4-500 rpms with the clutch in until the tires stop rotating, and then it goes right back up to 750 rpms.
It does it every time I come to a stop. It doesn't do with with the compressor on. It doesn't do it when the engine is cold.
The only thing I can imagine helping it would be a PCM update...but I don't know. There are no vacuum leaks and the idle is smooth. It just drops really low when coming to a stop.
So, you could try "increasing" or "opening up" you Idle Air Control position (or drilling out your TB hole <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
It's the basic of getting more air (less fuel)into the mixture at low RPMs, which is what your car is going into when you slow to a stop.
I'm not the LS1 guru but it's worth a try. <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" />
Troy
