SURGING IN GEAR BUT NOT NEUTRAL/PARK
Old Oct 29, 2002 | 12:16 AM
CAT3's Avatar
Restricted User
Default SURGING IN GEAR BUT NOT NEUTRAL/PARK
Today I noticed the slightest of surge while in gear at idle, but no in neutral or park. Of course, the dash tach isn't the most accurate, but it looks like the needle swings from about 490rpm's to 540rpm's in gear at idle. It keeps a rythme not sporadic. NO SES light, and not in neutral or park <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> Any help is welcome. TIA.
Charlie.
Old Oct 29, 2002 | 01:00 PM
CAT3's Avatar
Restricted User
Default Re: SURGING IN GEAR BUT NOT NEUTRAL/PARK
How can I check the EGR?
Old Oct 29, 2002 | 03:32 PM
BensZ28's Avatar
You idle at 500!?!?! I idle at 950 at the lowest! Usually at 1k. Should it be at that or should i mess with the throttle closed screw?
Old Oct 29, 2002 | 05:39 PM
CAT3's Avatar
Restricted User
If EGR doesn't work at idle then why would this have any effect on the idle? Or are you just refering to a leak at the intake fitting? Not leaking though-checked it. Changed plugs, no difference, will try wires friday and post up results.
BenZ-28, yep she idles at or about 500rpm in gear and like 550rpm in prak/neutral. Yes, these figures are off the factory tach.
The surging (hunting) for idle is not always while idling. Most of the time yes, but since watching it closely, there are times when it idles steady. Can't pinpoint it exactly, sometimes when cold, other times hot, coasting to a stop or engine breaking. Hopefully it is just the wires. They are 3 years old, although they only have 13,500 miles on them.
Old Oct 29, 2002 | 06:14 PM
Mikie C's Avatar
I have the same surging in drive at idle with my C5. The surging is intermitent. I too am curious as to what causes it.
TTT
<small>[ October 29, 2002, 06:15 PM: Message edited by: Mikie C ]</small>
Old Oct 29, 2002 | 06:22 PM
BensZ28's Avatar
Should the 500 be the same for M6's too? I might mess with my idle screw, the worst its going to do is idle rough
Old Oct 30, 2002 | 12:08 AM
CAT3's Avatar
Restricted User
ttt
Old Oct 30, 2002 | 12:28 AM
98TAauto's Avatar
when my EGR was going bad it would do that. Espically when i slowed coming to stoplights! The car wanted to stall almost. Not saying thats your prob, but it happened with my 98
Old Oct 30, 2002 | 09:23 PM
CAT3's Avatar
Restricted User
ttt
