PS pump pulley install problems
Old Apr 27, 2006 | 12:25 AM
Hal StClair's Avatar
Default PS pump pulley install problems
I went to install a new pulley on my power steering pump and actually broke the installer trying to do it. The pulley got real tight about 3/16" from all the way on and broke the bolt on the tool-any ideas here? Should you lube the shaft first? Oh yea, C5 type pump.
Thanks for any advice
Old Apr 27, 2006 | 03:31 PM
daryl2cb@yahoo.com's Avatar
lubing the shift never hurts, what tool brand were you using?
Old Apr 27, 2006 | 05:02 PM
Don't know who made the tool, my son had it in his box but I'm sure it was some off brand. I'm going to get a grade 8 bolt and use a nut and washers tonight and see if I can pull it on the rest of the way.
Old May 1, 2006 | 05:39 PM
John_D.'s Avatar
The LS1 f-body pump threads are SAE, not metric. Probably the same for the C5. Just fyi, in case that was part of the problem.
