Need a part # for the hose that goes from radiator to powersteering cooler
Does anyone know the part # for the hose that goes from the the radiator to the powersteering cooler. Its the inlet hose. Also, has anyone had any luck picking up this hose from a local parts store? Thanks
SSU's Drunk Typing Whore
I am pretty sure there is a part number thread in one of these sections...
https://ls1tech.com/forums/new-ls1-owners-newbie-tech/336996-request-part-numbers.html
Here you go:
1. Hose, Radiator outlet 98-02 10271555
2. Clamp 98-02 15024902
3. Valve (Part of 4) NPN
4. INLET, W PMP (includes 3,5,6) 98-02 12562740
5. THermostat (Part of 4)
6. Bolt (Part of 4)
7. Clamp, Throttle body outlet hose 98-02 11516217
8. Hose, TB HTR OTLT 98-02 12556452
9. Hose, Radiator INL
98-01 10271554
2002 10403194
10. Clamp, worm gear 98-02 22527587
11. Hose, Radiator inlet 98-02 10403194
12. Cooler PS Fluid 98-02 10417037
13. Hose, Rad INL FRT (MXD) 98-02 10413567
14. Cap 98-02 10402081
15. Screw M8x1.25x30 11514478
16. Grommet, coolant recovery pipe, 10213669
17. Resevoir 10402687
18. Cap, coolant recovery res 10188034
19. Clamp 1648216
20. Hose 10188032
21. Clip 10414272
22. Clamp 15024902
Not shown in picture (Picture is 00-02):
Module, Eng Coolant level indicator (includes seal) 98-99 10096163
Connector 98-99 12167116
6. Bolt (Part of 4)
98-01 10271554
2002 10403194
19. Clamp 1648216
20. Hose 10188032
21. Clip 10414272
22. Clamp 15024902
