oil cooler
Hayden 211 GM Chevrolet Oil filter cooler sandwich adapter.
I searched all over and finally found my records of purchases on my computer. Hope this helps you guys out, sorry it took me 3 weeks
Oil Cooler - I used a 24 pass TruCool cooler from RacerParts Wholesale -$45
Approx 11' of -8AN braided line - $80
8 -8AN ends - $4 ea
6 1/2" NPT to -8AN adapters $4 ea
3 -8AN 90 degree fittings - $10 ea
2 weld on -8 AN male fittings - $3 ea
-8 AN T fitting with 1/2" NPT on the top $9 ea
Autometer temperature sender, with 1/4" NPT to 1/8" NPT adapter - $45
GM Truck Oil Cooler Adapter and gasket (PN: 15725587) - $40
http://para.noid.org/oilcooler/
ttt for the oil cooler thread. Is there anyone else running one on a f-body?
8 -8AN ends - $4 ea
Ron Davis also makes serious heat exchangers that I would recommend. 7, 14 and dual 14 plate exchangers for serious cooling of hot fluids. In the Arizona mid day sun in dessert racing they drop oil temps 100*.
The integrated oil cooler in the radiator drop temps 30-40* and is a win win situation with the radiator providing 20% better cooling than factory in the first place.
