Water Pump Life Expectancy?
Old Apr 28, 2006 | 03:20 PM
ufsnola's Avatar
Default Water Pump Life Expectancy?
What's the average amount of miles before a LS1 water pump is prone to failure?
Old Apr 28, 2006 | 03:26 PM
WhiteRhino's Avatar
Mine's a 98 and around 55k it went out.
Old Apr 28, 2006 | 04:10 PM
joecar's Avatar
Starts leaking at 34K.
Old Apr 28, 2006 | 04:33 PM
taintedmeat's Avatar
I got my car at 94k miles, has it already been replaced?
Old Apr 28, 2006 | 04:44 PM
BIG BAD BLACKSS's Avatar
Well this makes me feel good being at 65K with the original one still!
Old Apr 28, 2006 | 05:11 PM
SiL3NtXWS6's Avatar
mine went out at 10,000 (after 3 1/2 yrs though) Now running an electric water pump
Old Apr 28, 2006 | 05:42 PM
lgobraves's Avatar
mines got 90k and still going strong
Old Apr 28, 2006 | 07:29 PM
Strahley's Avatar
~55k on mine over ~5 years, no problems here
Old Apr 28, 2006 | 07:36 PM
JBIRD02's Avatar
went out @ about 50,000
Old Apr 28, 2006 | 07:52 PM
98LS-WON's Avatar
96K, still works great.
Old Apr 28, 2006 | 10:40 PM
SUX2BU's Avatar
This question is like asking how long do your Nike running shoes last. Your gonna get 1,843,665 different answers.
If its not leaking its not broke. when it leaks on to your crank pulley replace it.
Old Apr 29, 2006 | 01:14 AM
BatmobileSS's Avatar
40k and 5 years, no problems
Old Apr 29, 2006 | 01:16 AM
'Trust''s Avatar
Mine had 120k on it before I replaced it, and it was still working just fine, I was trying to track down a cooling issue and it wasnt it.
Old Apr 29, 2006 | 01:20 AM
DOUBT IT's Avatar
I just replaced my gaskets on mine at 73,000, and the pump itself looks fine. No cooling issues or anything, apparently some robot at the factory installed my gasket wrong. :shrugs:
I don't see any reason to replace it until you start having problems, so I wouldn't worry about it.
Old Apr 30, 2006 | 11:40 AM
Travis99LS1's Avatar
my/n went out at around 37K miles...my car has 88K on it now and no problems so far (knock on wood)
Old Apr 30, 2006 | 11:42 AM
racer88's Avatar
73K miles on mine, original owner with no issues. I did however buy a spare alternator, seems 5 yrs is about the life out of them but funny it hasn't died yet and it's been 5.5 yrs.
Old Apr 30, 2006 | 02:36 PM
CRL 01 SS's Avatar
70k here, and still works great.
Old Feb 23, 2015 | 10:42 AM
Chevy1500Ext's Avatar
I am having sort of the same problem as you with the leak but I don't see the so called weeping hole and looked like the additive that I added to the coolant reservoir when I flushed the radiator. It seemed to be where it mounts to the block but I don't know now since I can't see it leaking anymore even with an inspection mirror. So my big question to you is, did you ever figure out where your leak was? Thanks.
Old Feb 23, 2015 | 10:58 AM
red_00z28's Avatar
Holy thread revival, back from the DEAD!!!! HAHA, But now that its back. I just replaced my pump yesterday with a new one from autozone. Not sure if it was the original pump but I'm at 166k so I highly doubt that its original.
Old Feb 23, 2015 | 10:59 AM
red_00z28's Avatar
Weep hole is behind the pulley. I replaced the gaskets on my old pump only to find out it still leaks. Save yourself the headache and just buy a new pump.
