Crank pully?
Old Apr 28, 2006 | 06:29 PM
MyCarIsSLow's Avatar
Default Crank pully?
Anyone got any tips on removing the crank pully?
Old Apr 28, 2006 | 06:46 PM
01MMMZ28's Avatar
Air Compressor, w/ good air impact wrench. Mine was a complete bitch to get off. If you don't have the air tools, get a friend and use a lenth of pipe as a breaker bar on put it over the end of the socket wrench and pull like a ****. Once it is broke loose, if you even need to remove it again it will be alot easier.
Sorry, that was for the pully bolt. You will need a 3 claw pully puller. They work wonders.
Old Apr 28, 2006 | 07:02 PM
well, im having problems with the bolt. heads are off and motor is practically completely apart..
Old Apr 28, 2006 | 07:04 PM
01MMMZ28's Avatar
It is put on w/ some crazy as torque specs from the factory, keep trying it will break loose.....took me and a friend 30 min. and 2 sockets cause we broke them w/ the air impact wrench.
Old Apr 28, 2006 | 07:10 PM
i dont have an impact... i guess i'll have to take the block up to work to get it off..
Old Apr 28, 2006 | 08:31 PM
01MMMZ28's Avatar
DAMN, shouldn't be that tough!! Try going to www.ls1howto.com or www.installuniversity.com to see if they have any other tips or tricks.
