Suncoast Hood Kit Questions
Old May 1, 2006 | 09:38 AM
Slvr98z28's Avatar
Default Suncoast Hood Kit Questions
hey guys I have a suncoast ss hood on my z and was wondering if it would be a big improvment to put the air filter kit they make to hood right to the hood. its like 300 bucks that's why I wondered if it would really be a difference.
Old May 1, 2006 | 10:21 AM
squealingtires's Avatar
Looks sweet! That's what I've got on my 2000 T/A. ON the T/A's The airflow takes the most direct route from the outside of the car int the engine. It basically changes its direction twice, horizontal into the hood then changes to a down direction as it passes through the filter then it moves horizontal again into the intake. The outlet of the airbox is between 85mm and 90mm too, I need to double check to be sure though. The filter area is nearly twice that of the regular filter too.
Old May 1, 2006 | 10:49 AM
daryl2cb@yahoo.com's Avatar
I see you have a lid, so I would just put the ram air under it, or even the super sucker, and you will get better results
Old May 1, 2006 | 02:38 PM
Slvr98z28's Avatar
well I have my trans cooler there tho so I didn't wna move that
Old May 1, 2006 | 05:55 PM
peterlawl84's Avatar
i have a raptor hood on my 99 t/a and it made a noticable difference when i went from the stock airbox to their airbox. when i got the hood, one of the pieces for the suncoast airbox was damaged so i drove around for a couple weeks with the suncoast hood and stock airbox.
Old May 2, 2006 | 08:17 AM
Slvr98z28's Avatar
well is the t/a ws6 hood kit the same as a camaro ss hood kit from them?
