exhaust problem...maybe cats?
when i let off the throttle at high rpm's...around 4500 or 5000, and let the exhaust resonate, it has started making a loud "pop pop pop" noise almost like a...shall i say...backfire? it's not a very consistant popping noise though, so i don't think it's a cylinder missfire or anything, because if it was it would be repititious or have some sort of pattern right? its hard to describe but this is the best i can do. i'll try to lay it out like this...
from 5000 rpm's:
"pop......pop..pop....pop.............pop"
sorry...thats about as good as it gets for a description, LOL
my SES light isn't comming on, so i don't think anything is wrong mechanically. i'm just worried that after to much bottoming out i've screwed my cats up. i've heard SLP is the worst as far as ground clearance, so i don't think it was my carlessness, cause i try to go over speed bumps as slow as possible, almost to the extent of stopping before i cross, but there has been quite a few occasions where no matter what i do, i know i'm bottoming out a little.
any ideas????
Hope that helps some.
