Why buy the Hooker Catback instead of the Hooker Muffler?
Any opinions?
Russ
<img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
good luck,
Shane
There just isn't alot of sense in paying out the nose so you can have a .25" larger pipe with the muffler. Besides, our pipes are mandrel bent stainless, they flow just fine on a mild to moderate LS1. You don't NEED more flow until you get into serious mods like H/C. By the time I was to spend all that money for H/C I would want more than .25" more pipe anyway... say 3" duals or 4" Mufflex. IMO the 3" cats are a waste of money.
Dave
Basically I just want the Hooker for the sound. No rasp at WOT and a not so loud, low idle. For flow, I'm installing a cutout so no problems there. What size are the factory outlets on the WS6? I'd rather just buy the muffler if it's possible, but I'm not sure on the size of the muffler outlet size.
Thanks,
Russ
Nate
Nate
you don't need a cutout with the hooker cat-back for 2 reasons
1.it flows good enough that you wouldn't see much of a gain
2.you don't need it with the hooker cat-back. cause all you hafta do is unbolt the 3 bolts from the muffler and drop it off. so that you not only get the benefit of a cutout but you also save weight as opposed to keeping the muffler on.
russ
