Over axel True Duals..
Originally Posted by bichin95redta
I don't think $1,500 is unreasonable for an over-axle, true dual set-up. Hell, I spent $800.00 for my Kooks, and $500.00 for my Magnaflow stainless cat-back.
Meent: that's a bichin' lookin' set-up. You have no clearance problems over the panhard bar? Nothing touches the floor pans, or fuel tank heat shield?
I had a bich of a time getting the over-axle pipe on my Magnaflow to clear the fuel tank heat shield. I must have loosened, adjusted, lengthened/shortened, and clamped/un-clamped that cat-back 15 times before I finally got everything just-so.
Did the shop offer you different tail pipe options?
Are the wheels ROH Snypers?
The wheels are CCW SP500s. They weren't cheap either
Seems like there are a lot of people in here that will bash others to death over how much they spent on certain things. I think that's just plain rude. Yeah, some of us get taken for a ride, but others are willing to pay a little extra for no hiccups along the way. Peace of mind is worth the extra money to me...to know it was done right the first time.
I try not to be foolish with my money, but I'm a huge believer in the old saying, "You gets what you pays for."
I may not be able to buy the best there is, but I do buy the best I can afford. High-quality stuff is expensive because the best materials are used, using the best manufacturing/assembly/QC techniques. That costs the manufacturer money, so it's going to cost you money. So far, I've yet to get burned by buying the best I can afford.....but I learned that the hard way.
It kind of ties into some of the arguements I've seen over brands, and brand loyalty. There's something to be said for branding. Companies like Kooks, Comp, Lunati, AFR, and others didn't get to where they are, by putting out inferior, low-quality products.
I only paid 700 for my exhaust not including the electric cutouts. It's 3.5 mandrel bent with an x to the axle, cutouts, then 3" over the axle through sweet-thunders then stock tips. The 3.5" may have been over kill and my ground clearance really suffered but I wanted the best flowing exhaust I could get. And it does detach at the neck down before it goes over and at the headers.
