Fuel Pressure Regulator?
Old Nov 22, 2002 | 03:19 PM
SnakeStomper's Avatar
Default Fuel Pressure Regulator?
Is it worth getting one of these? If so, which ones do you guys have and how has it helped. Thanks in advance for any responses.
Old Nov 22, 2002 | 03:59 PM
MIGHTYMOUSE's Avatar
Default Re: Fuel Pressure Regulator?
they are worth getting if you need one.. do you need one?
Old Nov 22, 2002 | 05:05 PM
Yeah it's something I'm looking into getting. Saw the one at ls1speed.com for about $130 .. I think I'll look/ask around. Thanks for the feedback!
Old Nov 22, 2002 | 07:20 PM
JetBlack98Z's Avatar
Hey Guys to My Understanding there is no way to get a Adjustable one for the 99' and newer ls1. The 97&98 Have them on the Fuel Rails and starting 99' they moved them inside the Fuel Tank.
Can Someone Justify My Knowledge <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
I heard this From T.P.I.S
Old Nov 23, 2002 | 12:51 AM
Interesting .... anyone have an answer? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Nov 24, 2002 | 08:06 PM
ttt
Old Nov 25, 2002 | 04:18 PM
jet black is misinformed, 98+ camaros and firebirds all have the stock regulator in the same place, in the tank.
i was assuming you'd remove this and plumb in the replacement somewhere outside the tank since that is standard procedure.
the 97 vettes were the only ls1 to have a rail mounted regulator and full return line.
snake stomper, i have the cas regulator on my car check these pics for my fuel system install, feel free to ask any ?'s
http://community.webshots.com/album/29211724vvFXlMScRb
David
<small>[ November 25, 2002, 04:22 PM: Message edited by: MIGHTYMOUSE ]</small>
Old Nov 25, 2002 | 07:00 PM
ToplessTexan's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by MIGHTYMOUSE:
<strong>the 97 vettes were the only ls1 to have a rail mounted regulator and full return line.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">MIGHTYMOUSE is also misinformed. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> The '98 C5 also uses the return line and rail mounted regulator.
If you're into PCM tuning, the AFPR doesn't do much for you that you can't do better and/or more easily w/ programming. If you increase/decrease the pressure IPW will decrease/increase in closed loop, the change really only impacts WOT (similar to MAFT, though w/o the side effects to load.)
Old Nov 25, 2002 | 08:52 PM
it happens <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" /> i've never laid eyes on a 98 vette.
I agree there is nothing you can do with a fpr that you can't do with tuning as far as hp output/driveability
for forced induction applications its just a good idea so all of your pressures stay in check, and for me it does make tuning much easier since i know my flowrate is always constant with its use.
Old Nov 27, 2002 | 02:32 AM
thanks for the info guys!
MIGHTYMOUSE: checked out your fuel sys. pics ... NICE!! Maybe this is just a mod i'll hold off on for now.
