How do I drain all coolant
Old Nov 22, 2002 | 09:53 PM
BigJ99TA's Avatar
Default How do I drain all coolant
I am a former Lt1 guy and am ignorant to the LS1 coolant system. Is there a plug in the block that I can remove to let all the coolant out?
Old Nov 22, 2002 | 11:32 PM
Farmer2's Avatar
Default Re: How do I drain all coolant
On the pass side there is a plug that lies flat just above the starter between the starter and the block. You'll need a 5/16 allen socket to remove.
On the drivers side in the front by the alt. theres a plug on the side of the block that you'll need a 17 mm allen socket to remove.
You may have to tap on the plugs lightly to loosen but then they come right out. Then after draining use teflon sealant on the plugs and install again.
Dave
