FAST Intake Gains
Old May 7, 2006 | 10:09 AM
Doveman's Avatar
Default FAST Intake Gains
This question as prolly been asked 1000x's, but what kind of gains are people seein when upgradin to the fast intake manifold, i would also be goin up to a 90mm tb
current setup is below, thanks
robb
Old May 7, 2006 | 10:18 AM
Ghostintheshell's Avatar
search? Im not sure myself
Old May 7, 2006 | 10:26 AM
HOSS's Avatar
Over the LS6 with ported tb, prolly 10 or so, with heads, maybe 15
Old May 7, 2006 | 10:27 AM
LS1SpeedAddict's Avatar
You would deffinatly see higher gains then I did becasue you have heads and a M6 but I got 19hp and 27ft lbs but I was also going from a LS1 intake.
Old May 7, 2006 | 10:31 AM
Doveman's Avatar
so it looks like i could spend 1100 bucks on somethin else for the nominal gains i would recieve?
robb
Old May 7, 2006 | 10:34 AM
4mula's Avatar
robb
yes sir.
the fast intake is best for bigger cubes.
Old May 7, 2006 | 03:56 PM
totally agree but I can see spending around 500 for an ls6 and a ported TB when I know I wll have to get an LSX later down the road for a direct port set-up or when I do an engine swap.
Old May 7, 2006 | 05:42 PM
HOSS's Avatar
yea, but the fast just doesn't give you the power up top, it increases the whole range of power, which is a good investment, have it ported to your heads, and make a lil more power. If you are staying N/A, its a must man.
Old May 7, 2006 | 06:29 PM
Y2KNJSS's Avatar
i still have the ls1 intake. can get a new fast intake for 700.00. should i do it. my mechanic said i will def gain 20 hp. looking 2 get some gears as well. with my set up, i think that should be plenty for me. famous last words
Old May 7, 2006 | 07:28 PM
Lithium's Avatar
SSU's Drunk Typing Whore
Spray it
Old May 7, 2006 | 07:49 PM
bad95killer's Avatar
It's all about the performance guys LSX are the top of the notch out there so if you're planning to get an aggressive H/C combo & stay all the way N/A the LSX definitely your ROUTE
peace
Old May 7, 2006 | 07:59 PM
TheBlurLS1's Avatar
That's what she said...
You'll also need to drop $400 plus on a new throttle body, keep that in mind.
Old May 7, 2006 | 09:10 PM
Doveman's Avatar
this winter im doin prc stage 1 heads and a trex cam 24x/24x .61x lifts on both end, so you guys would recommend the fast setup then
thanks
robb
Old May 7, 2006 | 09:16 PM
TheBlurLS1's Avatar
I think you would see more gains from spending that FAST money on a killer set of heads.
I also think having the better heads milled and running a smaller cam would net you more power than stuffing the t-rex in it and having to run stock compression.
