Whats the throttle body bump stop mod?
Old Nov 26, 2002 | 06:36 PM
OneQuickSS's Avatar
Default Whats the throttle body bump stop mod?
Ive heard of it several times but dont know what it is. I also wanted to know if you can do this mod on the 80mm BBK? Thanks. Can you explain how to do it.
Old Nov 26, 2002 | 07:25 PM
felton316's Avatar
Default Re: Whats the throttle body bump stop mod?
Most of the stock throttle bodies will not open 100% You're basicly grinding down the stop so the TPS sensor gets close to without going over 4.70 volts (100% open).
Old Nov 27, 2002 | 06:34 AM
unit213's Avatar
Administrator
http://installuniversity.com/install..._bump_stop.htm
Old Nov 27, 2002 | 06:08 PM
OneQuickSS's Avatar
So I guess I dont need to worry about it if Ive got the BBK 80mm t/b?
