hesitation between 2000 and 3000 RPM
Old Nov 27, 2002 | 01:48 PM
jgs27's Avatar
Default hesitation between 2000 and 3000 RPM
I have 99 Trans AM M6 and at part throttle not flooring it, the engine hesitates or bogs between 2,000 amd 3,000 RPM always. If you just floor it there is no hesitation between 2,000 and 3,000 RPM and the engine never misses and idles fine. It is all stock except for SLP air lid, SLP Y pipe and the SES light is not illuminated. Has anybody have ideas what is causing this ?
Old Nov 28, 2002 | 04:47 AM
ZR2877's Avatar
Default Re: hesitation between 2000 and 3000 RPM
Mine does the same thing I'm gonna guess its the spark plugs need changing. I'm gonna get mine changed within the next month. Have you changed yours yet. How many miles do you have on your car. Welcome to the site the people on here are as helpful as they come we will get a better answer soon. By the way I have 65000 miles and stock plugs.
Old Nov 28, 2002 | 10:28 PM
ZR2877's Avatar
ttt
Old Nov 28, 2002 | 10:45 PM
al's Avatar
al
Mine hase been doing the same thing since the weather has cooled down. It dose it at normal driving, but just while its cold and at much lower RPMs. It hesitates right after shifting, but goes away after it warms up. This probably has nothing to do with your problem, but I just want to help any way I can or can`t. It`s a 02 Z and this is my first winter with it. It`s probably normal. <img border="0" alt="[chug]" title="" src="graemlins/gr_chug.gif" />
Old Dec 2, 2002 | 09:32 AM
jgs27's Avatar
Mines has 42,000 miles on the stock plugs. I was planning on changing them and probaly will do it this week-end. I doubt if it will fix the hesitation but who knows. I was thinking it might be the MAF(stock) but have no way of checking it personaly.
Old Dec 4, 2002 | 05:10 AM
ZR2877's Avatar
Does anybody think the plugs are our problems?
Old Dec 4, 2002 | 02:05 PM
jgs27's Avatar
my experience with engines is when the spark plugs or wires or problem the engine will have a mis not hesitation. I have reset the PCM pulling the ingnition fuse but the problem still persists. I was wondering if a factory reprogram of the PCM was in order to correct some defect.
http://calid.gm.com/vci/. Maybe the PCM is the problem and needs to be reprogramed for some defect. I can just unplug the MAF and see if the car starts or runs to see if this is a problem. Thanks for the input at least I know this problem is not unique.
Old Dec 4, 2002 | 02:17 PM
Colonel's Avatar
"I have reset the PCM pulling the ingnition fuse but the problem still persists."
I'm not sure that reset the PCM. Try this...
Turn key on but don't start the engine.
Pull both the PCM Batt and PCM IGN fuses.
Wait a few minutes.
Turn key off.
Reinstall fuses.
Old Dec 5, 2002 | 12:45 AM
Colonel's Avatar
Strange, I swapped my stock MAF for a GMS yesterday and the hesitation that was there when shifting to 2nd at part throttle seems to be gone. <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
Try resetting your PCM or try another MAF.
Old Dec 5, 2002 | 12:47 AM
Colonel's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by ZR2877:
<strong>Does anybody think the plugs are our problems?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Could be if they are the stockers and high mileage. The stock ones suck once the platinum pucks begin to fall off.
