pulley ???
Old Nov 29, 2002 | 11:11 AM
heyitsTaJay's Avatar
Default pulley ???
i want to go with the ASP underdrive pulley, but do i want the whole 3-piece kit or do i want just one pulley? whats the best thing to do in this type of situation? will i have to take it off when i go to get warranty work done?? PITA <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
Old Nov 29, 2002 | 02:01 PM
Colonel's Avatar
Default Re: pulley ???
Three piece? You mean two...as in crank and alternator?
Just go with the crank pulley. The gains come from slowing the waterpump down...not from slowing the alternator down. Charging will be better without doing the alternator pulley.
Old Nov 29, 2002 | 02:02 PM
Colonel's Avatar
I never take mine off but some dealers are more liberal than others. Some will give you hassle about anything where as others really could care less. Just depends on who you're dealing with.
Old Nov 29, 2002 | 03:17 PM
2001CamaroGuy's Avatar
I went with the ASP crank pulley and the "over drive" (not the underdrive) alternator pulley. This way I am spinning the alternator at the factory speed. If you just do the crank, you are still spinning the alternator slower than the factory speed. You should not have any problems with warenty. When I thought I had bent a pushrod, the guy at the dealership said "as long as you have never opened the engine, you can bolt whatever you want on it."
Chris
