Header install fun....
Old May 8, 2006 | 11:15 AM
BlackLine's Avatar
Default Header install fun....
Well for starters my floor jack does not travel high enough to do the pass side so ill have to put it on my blocks or something...
but the big issue is on the driver side there is a 1 inch square block coming off of the block. this is the only issue in my way of placing my driver side header in.
has anyone else had this issue, because i was under the impression that pacesetters just slide right in place...
Old May 8, 2006 | 11:24 AM
slowscott's Avatar
Alot of people have this issue and just cut/grind the little block off.
Old May 8, 2006 | 11:28 AM
ShevrolayZ28's Avatar
Some people get them in without removing the metal tab, some don't. Do you have the oil filter off? That helps. And also, the driver's side is the one that I needed the car higher up for. I had the driver's side header standing almost straight up and down to slip it in and it was still A tight fit. I had to maneuver it around for a while before I got it up there.
Take a break and try again. Good luck.
Old May 8, 2006 | 02:16 PM
TheBlurLS1's Avatar
That's what she said...
Old May 8, 2006 | 02:21 PM
'02 SLP#686's Avatar
Hey, you got the number for Domino's - Oh wait, I see a phone book - I'll get it!
Sometimes taking a break helps... be patient.
Old May 8, 2006 | 02:23 PM
TheBlurLS1's Avatar
NOOOOOOOOOOOOOOOOOOOOOO.............squish........
It's really sitting on those 6-ton jackstands, I would definatly NOT get under the car without them.
Old May 8, 2006 | 03:05 PM
WhiteKnightZ28's Avatar
Tech Resident
Dont worry about that little block, just cut it right off. I used a sawzall (It cuts aluminum like butter) I just took off about 1/4" of it and the header slid right in.
Old May 8, 2006 | 04:22 PM
BlackLine's Avatar
my 2.25 ton jack stands were also maxed out should i look into some 6 ton ones?
 Michael S. Palmer
Old May 8, 2006 | 05:12 PM
2K2WS6TA's Avatar
Take off some of the heat shielding for the passenger side, should help a bit.
The drivers, just grind/cut some of that block off, header will slide right in.
Make sure it's 2 feet from k member to floor, did mine that way, and both sides went in fine
Old May 10, 2006 | 10:27 AM
BlackLine's Avatar
2 feet wow... did you put a 6inch block of wood on your floor jack?
Old May 10, 2006 | 10:41 AM
JDP's Avatar
JDP
my oil filter didnt get in the way, it was the oil diveter that was hitting it, once i took that off, it slid right in, just had to wiggle it around for a couple seconds.
i didnt have to take off the steering linkage or cut the metal tab, but it came damn close when i slid it in
Old May 10, 2006 | 10:55 AM
taintedmeat's Avatar
Lmao at the phone book
Old May 10, 2006 | 04:10 PM
2K2WS6TA's Avatar
The jack has a 26" max height (Craftsman 3 ton jack) so no wood or any other extra spacers required
