Hooker Cat-Back Broke?!?!
Old May 8, 2006 | 10:49 PM
BNKBRKR's Avatar
Default Hooker Cat-Back Broke?!?!
Has anybody had problems with this cat-back? Mine sounded good for a while now it seems to change pitch from time to time and every once in a while it has a rattle to it like an exhaust heat shield. I thought it was coming from the collector area but it is the muffler, sounds like a baffle or two broke the welds and are vibrating on each other. Has anybody else had this problem with theirs?!?!
Old May 8, 2006 | 10:51 PM
The PAT WS6's Avatar
no not at all it sounds different on a cold star up but thats about it? id check the heat sheilds around it
Old May 9, 2006 | 07:50 AM
Mr Incredible's Avatar
I've had mine for about a year now. I'm chasing a rattle, too.
The inch-wide band clamp holding the cat-back to the y-pipe has been my problem. Occasionally, I hear rattling coming from the back but I haven't been able to reproduce it on demand. It could be a heat shield on the gas tank, I think.
This week I got a new, stronger bolt to really close up the clamp. The noise has gone away but I'm still evaluating things.
Old May 9, 2006 | 08:01 AM
conan's Avatar
No problems here been on for over a year now.
Old May 9, 2006 | 08:02 AM
ls1mongrel's Avatar
Sound like something is loose and pipe is hitting the car, check it all out, it may a some time to chase it down !
Old May 9, 2006 | 08:17 AM
z-ya's Avatar
I thought the same thing happened to mine but it turned out to be
pieces of a disentigrated cat in the muffler.
Old May 9, 2006 | 10:19 AM
BNKBRKR's Avatar
ORY pipe on it, been on there since 10K miles, so I doubt it is a cat., I removed all of the exhaust heat shields except for the ones around the tank. I've checked all of my clamps and they are all tight. I will check the heat shield around the tank and the rear axle. Any other ideas? It seems to only do it when the car is in gear, like sitting at a stop light or very light throttle cruise at lower speeds (20-35mph) intermittently.
Old May 9, 2006 | 10:58 AM
ShevrolayZ28's Avatar
Rattles are sometimes hard to track down. It might be time to pull the muffler from the car and give it a shake and a look inside. Maybe something broke loose inside.
