Rasp?
Old May 9, 2006 | 05:43 PM
dregnier0's Avatar
Default Rasp?
Well got the tr230 cam into my 01 TA. I now need headers and a Y pipe to hook up to my borla exhaust. Problem being is ive heard alot of people saying it will get raspy as hell even with a catted Y pipe. I dont want to make my car sound like **** by doing this. What should I do? Ive been to lS1 sounds but that dosent do **** compared to hearing the car in person. Will this setup be annoyingly loud in the car while driving?
Old May 9, 2006 | 05:44 PM
Lithium's Avatar
SSU's Drunk Typing Whore
cats...
Old May 9, 2006 | 06:02 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Aluminum blocks will give you more rasp. You can tell by owning an LT1 and then getting an LS1.
Old May 9, 2006 | 06:03 PM
RaNsOm's Avatar
get a 12" dynomax bullet muffler and weld it into the Ipipe
Old May 9, 2006 | 07:02 PM
99Hugger's Avatar
I had a similar set up. LT's... ORY... Borla cat back. Rasp was pretty bad. I just installed a TSP catted Y pipe. Took about 80% of the rasp out of it. Cats do make a big difference when it comes to the exhaust sound.
Old May 9, 2006 | 08:09 PM
dregnier0's Avatar
Is the noise level in the car annoying or ok?
Old May 9, 2006 | 11:31 PM
TheBlurLS1's Avatar
That's what she said...
It would be about as good as you're going to get with LT's. I think you will be pleased with it. Cats do alot to refine the tone. I have dual 3" magnaflow cats welded into my TSP true dual system.
Old May 10, 2006 | 02:14 PM
dregnier0's Avatar
t t t
 Michael S. Palmer
Old May 10, 2006 | 02:36 PM
dregnier0's Avatar
Does it matter if I put bullet cats in myself or are the ones already in the Y pipe better? (Like the tsp catted Y)
Old May 10, 2006 | 11:05 PM
TheBlurLS1's Avatar
The TSP y-pipe is probably going to be better, with less hassle. You should just order that one.
Those cats flow plenty untill you make tons more HP.
