still problems with my TB
bretbauer@hotmail.com
at all. To seat the blade, just loosen up
the Torx screws and let the throttle spring
snap it shut a couple of times, then tighten
in place.
The throttle blade hole shouldn't be fucked
with on a normal car, the IAC takes care of
setting up the idle.
You should check the throttle cables and,
if you can catch it idling high while parked,
see whether it's down on the stop screw or
not; push it down and see if it's really a
mechanical bind, or the idle control system
that's in charge.
<strong>First question who ported the TB? Second any adjustments made to the TB other than porting? I suggest you contact Bret Bauer. He ports TB's. He may have some helpful info for you. Email below.
bretbauer@hotmail.com</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yeah I'm willing to help. It sounds like a throttle plate that is misaligned, simple fix should do it.
Bret
