LS6 intake over stock LS1?
Also, I would suggest getting headers before an LS6 intake. I did the LS6 intake first and my results were unimpressive. SAE max pre-LS6 was 316. After the intake with no tuning was 314, but the AFR had jumped )0.8-0.9. I pulled it back down to 13.0 or a little lower and it went to 317. Added timing from the stock values and got 323. The difference between each graph was uniform (ie. gains were across the board). I still have 98 manifolds, cats and the pancake Y-pipe so I know there's a lot left. Just letting you know my situation so you can make an informed decision. Good luck which ever path you choose.
I'd suggest headers/y-pipe before the LS6/TB, as they will net more power.
The LS6 intake will require you to buy new a new coolant pipe and 2 plugs (only a couple of bucks). There's been a few threads about it this week. You can use the existing gaskets/wires. Do a search and you'll find some info with the whole swap procedure.
