The Reckless $10 Coil Relocation Mod
Old Dec 19, 2002 | 04:59 PM
ZYA_LTR's Avatar
Default Re: The Reckless $10 Coil Relocation Mod
I don't think that water will be an issue, if they get wet there, then they were getting wet on the V/C's, so i wouldn't worry about water, beside's these coils are sealed, which is why the coil wire cover the connection fully, and the harness connections are water proof sealtite connectors. The water that runs down to the cowl, is routed to the side of the car anyways, they would get wet if you sprayed them only.
Old Dec 22, 2002 | 03:43 PM
1CAMWNDR's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by GeorgeC:
<strong>As far as you guys asking about wires... Use a cut-to-fit set of LT1 wires, since the optispark connector is the same as the LS1's coil connector. You'll probably have to buy an additional set of straight (180 deg.) spark plug boots, as all the LT1 applications used a 90 deg. boot.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">George, do you have a part number handy?
Thanks.
Old Dec 23, 2002 | 07:36 AM
Reckless's Avatar
Super Moderator
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 1CAMWNDR:
<strong>What about sections of rubber fuel line cut-to-length and put on the rod in between each coil?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Very good idea! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Dec 23, 2002 | 10:36 AM
1CAMWNDR's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Reckless:
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 1CAMWNDR:
<strong>What about sections of rubber fuel line cut-to-length and put on the rod in between each coil?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Very good idea! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Reckless, do you or anyone else have a part number for the wires and straight plug boots you used? I am thinking HARD about trying this in the next couple weekends <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> .
Think some 3/8" fuel line will slide over the rod easily enough?? <img border="0" alt="[Driving]" title="" src="graemlins/gr_driving3.gif" />
Old Dec 23, 2002 | 05:35 PM
1CAMWNDR's Avatar
OK. I have been all over MSD,Summit,JEGs, Autozone, etc. sites and I can't find a cut-to-fit set of plug wires with the LT1/LS1 coil boots.
Did you guys just buy 20 ft. of bulk wire and then buy the coil boots and straight boots?
HELP! <img border="0" alt="[kaboom]" title="" src="graemlins/gr_bomb.gif" />
Old Dec 23, 2002 | 05:59 PM
Reckless's Avatar
Super Moderator
Just bought a universal v-8 MSD set with straight plug boots. Then used coil clips from a set of stock wires. You will have to reuse your coil boots or try 90* boots. I actually had two sets of wires. One set had the straight plug boots and the other set had the straight coil boots. The LT1 kits have 90* plug boots.
Todd
Old Dec 23, 2002 | 08:23 PM
1CAMWNDR's Avatar
OK. Universal 8.5mm MSD wires for a V-8 with straight plug boots. Do the stock coil boots come off the stock wires prety easily? I think I will need to invest in some proper terminal crimpers. <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
Many thanks. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
<small>[ December 23, 2002, 08:26 PM: Message edited by: 1CAMWNDR ]</small>
