Crank bolt stripped!!!
that makes them a good bit easier to "pull" onto the crank. They were designed this way to SPECIFICALLY prevent the problem you just had, using a stock bolt to install the pulley.
Also, since it now is in your best interest to "dodge" using the first 1/4 inch of threads in the crank to pull ANYTHING on - get a setup of either the correct METRIC threaded rod, or cut a stock bolt off (check the hardware store first to see if you can find a bolt of the same diam and thread pitch as stock with a threaded area LONG enough to install the pulley with the bolt fully seated IN ADVANCE in the crank) and have somebody weld a ANOTHER bolt "butted" to it (the cut-off stocker) to fashion an installer.
If you're in doubt, explain to the dealer mechanics what happened and they should be able to handle it.
<small>[ December 14, 2002, 09:48 AM: Message edited by: Plum Crazy Rob ]</small>
ERic
