ticking sound??
Old Dec 20, 2002 | 12:43 AM
John98LS1's Avatar
Default ticking sound??
I just got done insatlling my hooker lt's and true dual setup, i know about ls1 lifer noise, but now since i have the headers i have like a ticking sound, pretty defined, please help. thanks
Old Dec 20, 2002 | 12:50 AM
Ryan23silverado's Avatar
Default Re: ticking sound??
my first and obvious guess would be loose header bolt(s). An exhaust leak like that will make a definite ticking noise.
Old Dec 20, 2002 | 02:41 AM
sited12's Avatar
Second guess would be spark plug wires not on all the way.
Old Dec 20, 2002 | 01:40 PM
numbZ's Avatar
OR...the valves in the AIR tubes that come off the exhaust.Restrictor plates can be made to limit the amount of exhaust going in.I don't have a link but someone did a good write up with pics on this site.
Old Dec 20, 2002 | 03:21 PM
John98LS1's Avatar
Old Dec 20, 2002 | 04:43 PM
WILWAXU's Avatar
Did you do this?
Old Dec 21, 2002 | 12:44 AM
John98LS1's Avatar
im going to do that, thanks
Old Dec 21, 2002 | 05:16 PM
MOBE's Avatar
You should also keep in mind that after a longtube header install, you will hear the valvetrain alot more. Kinda sounds like a sewing machine. That may be what you are hearing?
Old Dec 21, 2002 | 09:42 PM
99 Black Bird T/A's Avatar
If you want to do the air restrictor plate mod, and don't want to cut your own plates, Thunder Racing sells a block plate you can use. Just drill a 3/16 inch hole in the block plate and now it's a restrictor plate.
Old Dec 23, 2002 | 01:29 AM
John98LS1's Avatar
if i do that plate mod and it doesnt fix my ticking noise, what else should? thanks
Old Dec 23, 2002 | 09:32 AM
ApacheDrill's Avatar
Exhaust leak sounds on target. Can you tell were the ticking sound is coming from?
Old Dec 23, 2002 | 11:18 AM
John98LS1's Avatar
end of the passenger header
Old Dec 24, 2002 | 12:23 AM
robertbartsch's Avatar
the check valve restrictor vacuume air lines are fluttering....
add a restrictor plate (tin plate with a small 3/8 hole drilled in it) to the gasket flange on each header....they are pipes located on the header pipes near the heads ....the lead to a small tin can that contains a rubber valve for the emissions system..
Change this now or risk a burned-out check valve....
Old Dec 24, 2002 | 10:05 AM
mike c.'s Avatar
i had a ticking noise,sounded like a valvetrain problem. i did the block off plate drilled the hole,well....... it fixed my problem.90% of my ticking is gone. goodluck to ya.
