O2 sims question? How do they install?
Thanks.
a.) use a 21mm wrench to undo the rear o2 sensors from the y-pipe. you'll want to save these for possible future use.
b.) disconnect the sensor from the wiring harness and in the 4 slot end plug in your o2 sim.
c.) once attached zip tie up underneath the car avoiding places of high heat (transmissions, exhaust piping. secure them to other wire looms or misc metal fittings. also avoid your moving parts such as torque arm and driveshaft.
d.) the 24" o2 sensor extension you received is for the driver side front o2 sensor. i would recommend wrapping this up and around the motor mount/ k-member to avoid melting the looming onto the surface of the headers. the passenger side is long enough to reach from the wiring harness to the o2 bung.
if you are really paranoid about the sims taking on any amount of rain (doesnt hurt in any way), shrink wrap some saran wrap around the wire ends.
<small>[ December 20, 2002, 09:12 PM: Message edited by: X']['C WS6 ]</small>
