a little help please
Old May 16, 2006 | 10:30 PM
klujan13's Avatar
Default a little help please
did a couple searches but found no real write-up or description. how the heck to you change the fuel pump on a 98 T/A I got a quote from the dealer for like $600 bucks i almost --> so I called a couple autoparts stores and the damn fuel pump is almost 400 bucks any advice would be appreciated thanks in advance.
Old May 16, 2006 | 10:59 PM
2K2WS6TA's Avatar
Basically you have to drop the tank, it's a real PITA (especially if the tanks full) drop the rear out, then the tank.
FWIW I did it on a 3rd gen, and I'd pay $600 just to avoid the hassle
Old May 17, 2006 | 01:31 AM
TheBlurLS1's Avatar
That's what she said...
You can cut a hole in floor between the rear speakers after you push the carpet back, people do it all the time.
You can pick up a nice plug and play fuel pump from our sponsers that will flow more, but still be able to be used on a stock setup. Most of the time, you are forced to buy the entire harness.
Here are some writeups.....
http://www.public.asu.edu/~nicolasd...umpinstall.html
http://www.geocities.com/formulapower2/fuelpump.html
And here's the kinda pump I'm talking about.....
https://www.horsepowerengineering.co...7b48565593c743
Old May 24, 2006 | 11:10 AM
klujan13's Avatar
ok so I just got the fuel pump in today from TSP and I have read the write-ups above and I know its been done I just am a little uneasy about cutting right above the fuel tank and making sparks. Do you guys have any pointers or advice so I dont blow up me or my T/A? Thanks in advance
Old May 24, 2006 | 11:48 AM
Nasty N8's Avatar
Do it the right way and take the tank out the bottom. Not that much more work. Nothing like cutting a big hole in the floor of your car.
Nate
Old May 24, 2006 | 11:51 AM
rgaynor85's Avatar
its sealed dont worry about it just be careful not to hit anything underneat with whatever your cutting with thats all
Old May 24, 2006 | 03:11 PM
daryl2cb@yahoo.com's Avatar
I would drop the tank, I would not cut the floor. tank come out easy, you then can support it on a jack if it is full then use the jack to get it back up in the car. if you got the walbro, you are going to have to hack saw the bottom of the fuel bucket, then remember to not run lower than a 1/4 of a tank, or you could be changing it again.
