Putting 2 Bullets in the I-pipe?
Old Dec 31, 2002 | 05:49 PM
FAST LS1's Avatar
Default Putting 2 Bullets in the I-pipe?
I'm going to be reworking my exhaust soon and I'd planned on adding another 12" Bullet to the 18" one currently in my I-pipe. I'll be replacing the stock I-pipe with a 3" piece so I'll have to cut the old Bullet out anyway. I've looked at the space under there and it's pretty tight, I think I can fit both in but I'm not sure. Has anyone put both an 18" and 12" Bullet in the I-pipe succesfully? I currently have Hooker LT's and their y-pipe with the stock exhaust and a cutout.
Old Jan 1, 2003 | 11:33 PM
OBSSSD's Avatar
Default Re: Putting 2 Bullets in the I-pipe?
You won't be able to do it and it wouldn't do much extra anyway.
Old Jan 2, 2003 | 12:39 AM
roadrunner-r's Avatar
Why wouldnt it help? I thoght the longer the quiter. I think it could be done,just cut the new short on both ends/ or try one.
Old Jan 2, 2003 | 03:13 AM
Dope's Avatar
Personally, I think you'd be just short.
Check this out:
<img src="http://www.fear.net/~dope/camaro/exhaust/relocated_bullet+cutout/new_cutout+bullet_location-from_driveside_viewpoint.jpg" alt=" - " />
This is my car. 12" bullet with the first end cut off, attached right to the y-pipe collector. We left the rear-most end on. Approximately 6" of piping, then 6" of cutout, and then immediately into the over-axle pipe. Including the end, that's about 14" MAX. An 18" bullet with the ends cut off is 16.5". Just shy, unfortunately.
Now, if you have stock manifolds and y-pipe, you could do it. I have FLPs, which relocate the y-pipe about 4" back. I had to cut 3-4" or so off my intermediate pipe to mate up to the FLP y-pipe. That would give you just enough length to do it. You'd have to watch the clearance under the crossmember though, maybe. You'd have an intermediate pipe made of bullets, heh. Would probably flow pretty well and quiet it down a lil more. Not a bad idea. Personally, I'd just get a quieter muffler, but whatever works!
Dope
Old Jan 2, 2003 | 05:35 PM
Dope do you have any more pics of your exhaust?
Old Jan 3, 2003 | 10:42 PM
Ragtop 99's Avatar
I have the 18" bullet and cut-out on my exhaust. It just fit. The bullet is welded to the cut-out.
Old Jan 3, 2003 | 11:40 PM
Dope's Avatar
http://fear.net/~dope/camaro/exhaust
Tons <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Dope
