Is it posible to take off the I pipe without cutting ?
Old May 18, 2006 | 05:58 PM
SS DNA's Avatar
Default Is it posible to take off the I pipe without cutting ?
Im having a hard time taking it off. The only other way is to use a sawsall and cut it. But I dont have one.
Any tips ???
Old May 18, 2006 | 06:27 PM
TheBlurLS1's Avatar
That's what she said...
I think you can drop the rear end down by removing the lower shock bolts, but don't quote me. I think people have done this and removed it through the right rear fenderwell or something to that nature.
Old May 18, 2006 | 06:30 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Exclamation
I have a WS6 and my exhaust was welded at the I and at the Y and at the over the axle also...I bought this car with 8 miles brand new at dealer. I had NO CLAMPS at all....just cut the damn thing..
Old May 18, 2006 | 07:29 PM
Lithium's Avatar
SSU's Drunk Typing Whore
yeah its possible...how though I have no idea.
I do know that its a major pain in the *** cause I was going to do it.
Old May 18, 2006 | 07:32 PM
2K2WS6TA's Avatar
If you really want to take it off whole, you're going to have to undo the rear shock, and take out the spring, then lower the rear, you might get away with doing it on the one side (pass)
As much of a PITA as it's going to be, you'd be better off, IMO, cutting it
Old May 18, 2006 | 07:35 PM
you2slo's Avatar
And you'll have to be on a lift. Just go to the parts store and buy a cheap hacksaw.
Old May 18, 2006 | 07:44 PM
TheBlurLS1's Avatar
Now would be a good time to invest in a die-grinder with a cutoff wheel. Mine made short work of my old I-pipe.
I've used that thing for so much it's not even funny. I've cut motor mount housings, made blockoff plates that went on 3 cars, cut bellhousings (don't ask), ported a FAST 90, polished valvecovers/throttle bodies, cut bolts, sanded slipfits, cut the radiator support.
It's like a Dremel on crack.
Old May 18, 2006 | 08:08 PM
blkbird's Avatar
I did it at my firends garage and all you have to do is unbolt the rear end from the shock and take the spring out. Have a buddy put pressure on the axle and you should be able to wiggle it out. I have the complete exhaust without cutting it, muffler tips and all.....
Old May 18, 2006 | 08:53 PM
SS DNA's Avatar
Cool
Well let me tell you guys that I did it. I dont know if I was the first person to ever but its done. I started by hammering a flat head screwdriver at the junction of the I pipe and the Catback. You have to hammer it alot and basically what I was doing is making the pipe on the cat back flare out a little or enough to wiggle the I pipe out...... It took a LONG time and about three cuts on my freaking hand.......
Thanks for the help though guys!!!
Old May 19, 2006 | 09:46 AM
you2slo's Avatar
Remind me not to work on a car with you. But glad you got it off.
