True Duals$$
http://i30.photobucket.com/albums/c3...k/a26cc10b.jpg
http://i30.photobucket.com/albums/c3...k/28fcfc45.jpg
http://i30.photobucket.com/albums/c3...k/ac811ddf.jpg
http://i30.photobucket.com/albums/c3...k/HPIM0350.jpg
http://i30.photobucket.com/albums/c3...k/HPIM0349.jpg
http://i30.photobucket.com/albums/c3...k/HPIM0343.jpg
http://i30.photobucket.com/albums/c3...k/HPIM0100.jpg
this is the front half of an OTA setup ive started.
http://i30.photobucket.com/albums/c3...k/HPIM0091.jpg
with cats of course.
http://i30.photobucket.com/albums/c3...k/HPIM0097.jpg
http://i30.photobucket.com/albums/c3...k/HPIM0093.jpg
http://i30.photobucket.com/albums/c3...k/HPIM0092.jpg
http://i30.photobucket.com/albums/c3...k/HPIM0090.jpg
and a little ground clearance shot for you with cats....
http://i30.photobucket.com/albums/c3...k/HPIM0107.jpg
Any more questions?
That being said, im jealous of your clean beads and stainless tubing.
One thing you need to do, is convert your flux setup to a gas setup...and change wires...they will weld much cleaner! I puked because of the placement of cutouts...(personally thank its retarded since you arent going to gain much with the magnaflow mufflers uncapped) and the red gum stuff you put on there...other then that ive seen ALOT worse from local shops here in TX.
Thanks for the heads up on converting to MIG. Im already setup for it, I just have to buy a canister and the wire. The welding place isnt open on weekends though, so i never get a chance.
Includes
Mandrel bent 3" aluminuzed tubing w/3" X-pipe
Additional 90* bend which will allow installation with most Long tubes
Race Magnum 3" Bullet mufflers, pair
Pair of universal exhaust hangers
Its a non-assembled kit so there'll be some fab work.
Plenty of kits out there. The cheapest ranges for ~$110 (Flowtech X pipe) or $1000+ for something thats custom and over the axle. But on average, I'll say if you go w/ something like the TSP or Speed Inc setup packages you're lookin at right around $500-$550
